Hi,
Just started to test out Beatport Link with Virtual DJ on PC version, found that track in pre-listen box could not jump to different position horizontally on the time bar and has to pre-listen from the very beginning.
( Most tracks in Beatport has around 60 seconds of raw beat intro so pre-listen from beginning is pointless in this situation.)
Please refer to attached photo.
The photo shows the pre-listen bar, for example, when the mouse cursor clicks that position in the horizontal bar, the song preview do not Jump to that point as expected.
Please consider to fix.
Many thanks
Best Regards,
Richard Artimix
P.S. I also use iOS DJay on iPad as my backup system which can jump horizontally on its' time bar.
Many thanks
Best Regards,
Richard Artimix
geposted Fri 02 Jul 21 @ 4:24 am
Yesterday I updated to latest version of VDJ PC and tried again, this problem has been solved.
Thank you very much development team.
Best Regards,
Richard Artimix
P.S. This topic can be closed please.
Best Regards,
Richard Artimix
geposted Mon 12 Jul 21 @ 9:45 am
