The main filter knob does not work. when you turn to the left or right nothing happens and instead of the circle trace of intensity being the color of the deck (in this case blue), it is grayed out.
Any advice? Seems like its some sort of setting? See pic for example
geposted Fri 02 Jul 21 @ 11:56 pm
Look close to the "old" skin but not really (filter is gray when off but trace still blue)
Maybe the skin in used must be specified
The old skin used to implement double click on the label to activate filter
In anyway if filter is off you can map a button to filter_activate
geposted Sat 03 Jul 21 @ 1:15 am
