Can someone tell me what this exactly means? I searched the manual, but couldn't find anything about this new feature?
-Pioneer Link now supported for any combination of DJM-900NXS2, DJM-V10, CDJ2000NXS2 and CDJ3000
Just start VDJ and link is enabled already? Or?
geposted Sun 04 Jul 21 @ 12:48 pm
          Before the update you could use link combining djm-900nxs2 and cdj-2000nxs2. With the update you can combine the 4 mentioned devices.
https://www.virtualdj.com/manuals/hardware/pioneer/clubsetup.html
geposted Sun 04 Jul 21 @ 6:28 pm
          Nice!
Only works connected via usb to the djm? Or works too with Ethernet?
geposted Sun 04 Jul 21 @ 9:24 pm
          DJM needs to be on usb and every cdj device incl djm , needs to be connected to the same router via ethernet
    geposted Sun 04 Jul 21 @ 9:57 pm
          And what about the XZ? The Pioneer site states the "Link Export" USB driver is for some all-in-one devices too?
USB Connection (Link Export) driver for Windows10
Updated 9 months ago
USB CONNECTION (LINK Export) DRIVER FOR Windows10
This driver software will allow you to use rekordbox Link Export feature via USB connection.
You can use this driver software for the models below.
CDJ-2000NXS2
CDJ-TOUR1
XDJ-1000MK2
XDJ-XZ
XDJ-RX2
XDJ-RR
Or am I wrong and VDJ doesn't support link export (for using the VDJ music database) but it's just for HID control with all connected devices trough LAN? (and DJM with only 1 USB to PC) ?
CDJ-2000NXS2
CDJ-TOUR1
XDJ-1000MK2
XDJ-XZ
XDJ-RX2
XDJ-RR
geposted Mon 05 Jul 21 @ 5:33 pm
          We are talking about HID over Link, same as if you use Rekordbox in performance mode.
Standalone Link (Link Export) is something different.
geposted Mon 05 Jul 21 @ 5:50 pm
royvanmeel wrote :
..but it's just for HID control with all connected devices trough LAN? (and DJM with only 1 USB to PC) ?
Exactly that! :)
geposted Mon 05 Jul 21 @ 6:33 pm
          Ah ok, now I understand. Thanks for the explanations!
    geposted Mon 05 Jul 21 @ 7:22 pm
