I discovered that I cannot have two filter folders that start with the same string of letters. For example, I want a filter folder called "Reggae" and another called "ReggaeRiddims". If these both exist, one of the two loses their set color property and sort order if you close VirtualDJ and reopen it. One of the two filter folders always gets moved to the bottom and reset to having no color coding property. The same thing even happened with "Reggae" and "ReggayRiddims". I was able to finally get it to work with "Reggae" and "RRid", however, so maybe it has to match the first three letters or so? I looked at the "order" file text in VirtualDJ/Folder/Filter/order and this always seems to reflect the correct order and color information even if VDJ fails to load in the correct order and colors on restarting.
Extra Troubleshooting Info
I am using v8.5-64 b6541
I have already gone through and double-checked I have full Windows permissions on all files and folders involved.
Here's the order file contents that would not work:
Filter Folder
Riddims
Reggae|#6DFF6D
Reggae Riddims|#6DFF6D
Dancehall|#FFFF6D
Dancehall Riddims|#FFFF6D
Soca|#FF4949
Soca Riddims|#FF4949
Electronic Music|#FF6DFF
Compatible songs
Decades
Genres
Last played
Most played
Recently added
And here's the one that finally did (with awkward naming):
Riddims
Reggae|#6DFF6D
RRid|#6DFF6D
Dancehall|#FFFF6D
DHRid|#FFFF6D
Soca|#FF6D6D
SRid|#FF6D6D
Electronic Music
Compatible songs
Decades
Filter Folder
Genres
Last played
Most played
Recently added
Thanks!
Filter Folder
Riddims
Reggae|#6DFF6D
Dancehall|#FFFF6D
Soca|#FF4949
Compatible songs
Decades
Genres
Last played
Most played
Recently added
Riddims
Reggae|#6DFF6D
RRid|#6DFF6D
Dancehall|#FFFF6D
DHRid|#FFFF6D
Soca|#FF6D6D
SRid|#FF6D6D
Electronic Music
Compatible songs
Decades
Filter Folder
Genres
Last played
Most played
Recently added
Thanks!
geposted Sun 04 Jul 21 @ 9:24 pm
Thanks for reporting, bug was indeed found and will be fixed in next update
geposted Thu 08 Jul 21 @ 10:10 am
