Anyone else having issues with the EQ modes not working? Every thing was fine, and then after an update all of my EQ modes operate as traditional instead of stems, vox, kick, etc.
geposted Wed 07 Jul 21 @ 6:13 pm
Try to set mathEngine to cpu (from Settings-》Options)
geposted Thu 08 Jul 21 @ 4:04 am
Having same issue. EQ modes not working, it resets to traditional EQ settings. Change math engine to CPU with no change in results. It was working before last update. I run VDJ8 with an iMac:
Processor Name: Dual-Core Intel Core i5
Processor Speed: 2.3 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache (per Core): 256 KB
L3 Cache: 4 MB
Hyper-Threading Technology: Enabled
Memory: 8 GB
L3 Cache: 4 MB
Memory: 8 GB
geposted Sun 11 Jul 21 @ 4:46 pm
Make sure precomputeStems option is set to create manually to calculate stems on the fly.
geposted Sun 11 Jul 21 @ 4:49 pm
It worked!!! many thanks.
geposted Sun 11 Jul 21 @ 5:07 pm
