Topic: Virtual dj 8 freezing
Hey there does anyone know why the latest version of Virtual dj continously freezes?
I do not have an issue with Serato Dj...
geposted Thu 08 Jul 21 @ 2:11 pm
Need more info dude.
geposted Thu 08 Jul 21 @ 2:25 pm
Issue with lyrics freezing during karaoke shows. Not consistent. Happens sometimes when I am typing , but not always. I thought it was something to do with my computer being older and memory almost full. Bought 2 new fast computers and I have the same issue with both of them. I am now wondering if programs running in the background might be an issue. Is there a way to check for compatibility? Any suggestions welcome.
geposted Thu 08 Jul 21 @ 5:16 pm
Are you using an external drive?
geposted Thu 08 Jul 21 @ 5:19 pm
YES. Using an external drive. Always have without any trouble until about 6 months ago. If that is the issue what can I try to correct the problem?
geposted Thu 08 Jul 21 @ 8:33 pm
Cleaned and optimized drive. Trying it out tonight at show. Thanks for the thought.
geposted Thu 08 Jul 21 @ 10:01 pm
Also check Windows isn't putting the drive or the USB port it connects to to sleep automatically. The delay can be the drive spinning up from sleep.
geposted Thu 08 Jul 21 @ 10:07 pm
Thank you so much! I'll check the port too. Cleaning and optimizing helped. Last night went well with a only one issue.
geposted Fri 09 Jul 21 @ 4:16 pm
