Hi,
I'm using Virtual dj 32bits and for a long time now the sound crackles while loading musics from deezer ou idjpool.
How can I fix this problem ?
Thank you in advance for your help !
geposted Fri 09 Jul 21 @ 10:06 am
Odd, even if a conflict or interference from the wifi, strange if its only when loading songs..
But try set buffer higher at the soundcard (if Asio) , or in VirtualDJ (if not asio driver), under latency in settings.
Set to 256 or 512.
Can also use this tool, try it while running VDJ and loading song from online. See if there is any spikes in drivers etc https://www.resplendence.com/latencymon
Set to 256 or 512.
geposted Fri 09 Jul 21 @ 12:16 pm
