I updated the windows driver from Denon DJ http://cdn.inmusicbrands.com/denondj/MC6000Mk2/Denon-DJ-MC6000MK2-Win-1.0.3.zip and upon opening the VDJ the volume controls are set to maximum and are not zeroing out. I have to move them up and down for the volume to be down. Hoping someone might know how to get VDJ to default have volume all the way off until the controller moves up. The ASIO drivers were causing issues until i set the buffer higher.
geposted Sun 11 Jul 21 @ 2:46 am
It also seems to skip when using automix anyone else have this? Its like a freeze or glitch
geposted Mon 12 Jul 21 @ 7:13 pm
i too have this problem with the mk2
geposted Tue 12 Apr 22 @ 11:56 pm
Its not always possible to detect the fader position at start up.
But you can set controllerTakeOverMode in VirtualDJ to be instant ( then volume react immediately when moved)
Or you can set VirtualDJ to start with volume down if thats your prefered mode of operations
In the keyboard mapper set ONINIT to : deck all level 0
geposted Wed 13 Apr 22 @ 5:44 am
