Hi, all.  I'm new to DJing but less new to music in general.  The beginner controller everyone seems to recommend is the DDJ-400.  There's two things, though:  It makes the VDJ Home Plus license $100 and I feel like I can start with something cheaper to see if I stick with it.
Do any of you know a controller you can recommend that also has a $49 VDJ Home Plus license fee? If I can stick with DJing for two years, maybe I'll step up to a DDJ-1000 or something and get the Infinity license.
TL;DR - Set me up cheap, Senpai.
Thanks
Thanks
geposted Mon 12 Jul 21 @ 12:16 am
geposted Mon 12 Jul 21 @ 1:29 am
          Also have at look at the numark partymix it is better than the dj2go2 and the home licence is the same price at $49 and it will control the stems the dj2go2 will not as it has  no Knobs to control them  so I would recommend the partymix.
    geposted Mon 12 Jul 21 @ 3:01 pm
          stems can be controlled with the pads as well as knobs :-)
    geposted Mon 12 Jul 21 @ 7:10 pm
          I find the stems are more  controllable  with the knobs
    geposted Mon 12 Jul 21 @ 7:32 pm
