Hi Folks,
I'm using Beatport Link in conjunction with VDJ since one year now and have to say, that it is like a dream coming true to find and test new tracks.
I know that I was able to create a new playlist in the Beatport Folder in VDJ and was able to add Beatport tracks to it. The playlist was synched with Beatport and I was able to purchase the song selection easy. Since some time (I don't know exaclty when it stopped working), I can not add tracks any more. And tracks are not synched to Beatport, too.
I can create a playlist and give a name which I'll find on Beatport afterwards, but tracks are always empty.
Here are the steps to reproduce:
1) Open VDJ and navigate to Beatport Link folder
2) Right click on Beatport Link and choose "Create new playlist"
3) Give a name and press OK
4) Add some Beatport Link songs to the playlist.
5) The songs are displayed in the playlist.
6) Navigate somewhere else and come back to the playlist.
7) The playlist is empty and all added songs are gone.
I know that this worked once before.
Is this a bug or is the feature not supported any more?
Cheers Jochen
Cheers Jochen
geposted Mon 12 Jul 21 @ 7:00 pm
Same issue here, this used to work
geposted Thu 15 Jul 21 @ 8:37 am
Tried here and tracks are correctly added
geposted Fri 16 Jul 21 @ 12:59 pm
Hey Adion,
thx for the feedback. Did you navigate to a different playlist and return to the original playlist?
I did a video on how it looks like on my computer:
https://youtu.be/fNegYCFSYLw
Cheers Jochen
Cheers Jochen
geposted Sat 17 Jul 21 @ 3:55 pm
do you have auto save playlists on?
if not check that setting could be it
geposted Sat 17 Jul 21 @ 5:19 pm
Hey Wicketmix,
did you mean "savePlaylist" under Browser Options?
This has been set to "Yes".
geposted Sat 17 Jul 21 @ 6:14 pm
The issue has been found, will be fixed shortly.
I was testing with the 32 bit version of vdj first, but the issue only occurs with the 64 bit version
geposted Sat 17 Jul 21 @ 7:18 pm
Awesome!
Thank you Adion!
Thank you Adion!
geposted Sun 18 Jul 21 @ 6:07 am
