Hi,
We having a license under its@oranim.ac.il
email.
Today the audio settings were reset.
every time I try to change the audio settings and exit from the program it reset the settings.
I checked if the user has full permission to the VirtualDj folder, the user has full control.
email.
geposted Thu 15 Jul 21 @ 7:02 am
It looks like sometime threads don't end or are taking a very long time (many minutes) to stop and prevent to save settings (or next run to read them before last thread was ended) with recent builds and some configs
Take a look at task manager or even resource manager and wait the thread to end or force close or simply restart computer
Then you can run VDJ again reading settings and database
For audio settings you can (may) force writing (and rename) with little disk icon bottom right of audio page
To be sure correct settings and database are read, enable column 'first seen' and verify not all tracks are current date
geposted Thu 15 Jul 21 @ 8:59 am
