Hello, have VDJ something like Serato beatmatching display ? https://support.serato.com/hc/en-us/articles/225126448-Beat-Matching-Display
This is very useful beacuse if you have song without beatgrid you can beatmatch just with your eyes and ears...
I have search for something like that in VDJ but can not figured out....
Regards
Regards
geposted Thu 15 Jul 21 @ 11:53 am
just line up beat grid markers .. as long as you have the grid adjusted correctly
more info here -> http://www.virtualdj.com/manuals/virtualdj/interface/topsection/rhythmwave.html
geposted Thu 15 Jul 21 @ 12:22 pm
Thanks for reply...
I allready check this, but you need to beatgrid tracks before or i'm looking for something similar to Serato like i said....
I play a lot tracks from 70's & 80's and in Serato is easy to beatmatching using ''beatmatching display''. With VDJ it's a little harder.....
geposted Thu 15 Jul 21 @ 12:38 pm
You can use the rhythm wave for that:
https://www.virtualdj.com/manuals/virtualdj/interface/topsection/rhythmwave.html
geposted Thu 15 Jul 21 @ 12:42 pm
waveform have to be set to "Beats"
It does not display as serato though but beatmatching is almost the same
geposted Thu 15 Jul 21 @ 12:48 pm
I set waveforms in "color"'....anyway waveforms are not so high, it's a little hard to beatmatch even i set waveforms to "beat".....
geposted Thu 15 Jul 21 @ 4:09 pm
At the end, rhythm waveforms beats can be split ?
Regards
Regards
geposted Fri 16 Jul 21 @ 11:55 am
geposted Fri 16 Jul 21 @ 12:37 pm
