I have a denon mc6000mk2, the volume fader on 2 stopped working. sent it to denon in nj who said the part is no longer available, should they "trash the unit" or send back. im 63, 42 yrs in and do basically small events or free events for a local animal shelter. the outside two volume faders have NEVER been used, can this unit be mapped so i can just use the outside volume faders with vdj. not a tech person so responses in simple form are appreciated...thank you. not really looking to break the bank on a new unit with bells and whistles i don't need
geposted Fri 16 Jul 21 @ 9:17 am
They're lying to you
https://instrumentalparts.com/channel-fader-denon-mc6000-mk2-mc4000-other/
unfortunately yet another controller were what should be a 10 minute fix of a consumable component isn't.
fortunately there's a setting you can switch, [mixerOrder] to use the outside chans as 1 & 2 [1,3,4,2]
geposted Fri 16 Jul 21 @ 9:49 am
if it's only fader, ... can always be fix
https://www.youtube.com/watch?v=88n6noeuUJ0
geposted Fri 16 Jul 21 @ 9:54 am
