Is there away to select a specific key, so if i have a tone looped i can play it like an instrument?
geposted Mon 19 Jul 21 @ 8:53 pm
check set_key verb
geposted Mon 19 Jul 21 @ 9:06 pm
Thank you. I'm not sure if it's changing to the exact key, but it's better than just applying semitone up or down as I have moe control and know what im applying more, and I think I have abetter chance of getting it to do what I want. Plus it doesn't matter what notes are played as long as the following notes are in the same relation to each other.
geposted Thu 22 Jul 21 @ 10:26 pm
