Hey I'm writing this since I haven't found a post about this. Maybe I'm not good at looking for things but I've been looking for this the past 2 weeks so this is easier now.
I can't find any setting to change the FX on the FX pads (FX1, FX2, FX3 etc.)
Could you help me with that, I know it's probably easy but I've been using Serato DJ Pro and DJUCED and I have no idea how to do it here since this is more config based.
geposted Thu 22 Jul 21 @ 10:03 am
they're "FX Slots", not pads, pads are the 8 button groups.
http://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/effects.html
geposted Thu 22 Jul 21 @ 10:10 am
That's not it.
This is what I mean. By changing what you sent, my FX do not change
geposted Thu 22 Jul 21 @ 10:16 am
Ah my mind reading isn't great towards the weekend
Hercules inpulse 500? look at the mapping for these entries
MIXER_FX[n] (1-4)
you've also got these to play with
SHIFT_MIXER_FX[n] (1-4)
MIXER_FX[n] (1-4)
deck all filter_activate 'FXNAME'
geposted Thu 22 Jul 21 @ 10:44 am
Thank you very much sir. One more thing if it's not too much already. Do you know where I can find a list of all the effects? Cause there is a very very short one when you click on the arrow, and I don't know if that really is all of them.
geposted Thu 22 Jul 21 @ 10:58 am
fx slots or filter fx ? [again mind reading, isn't the best]
be default what you see is what you get there are addons you can download, some won't work too great as a filter fx though.
geposted Thu 22 Jul 21 @ 11:21 am
maybe you want this ?
http://www.virtualdj.com/plugins/index.html?category=effects&subcat=1
its also inside virtual dj in the settings where you install addons
geposted Thu 22 Jul 21 @ 11:46 am
Here is the list of native Effects (using effect_active, effect_select etc actions) https://www.virtualdj.com/manuals/virtualdj/appendix/nativeeffects.html
For Mixer/Color FX (using filter_activate as the 4 buttons on Impulse 500 are using) see .. Nr.8 from https://www.virtualdj.com/manuals/virtualdj/interface/mixer/audio.html
If you want to change the Color/Mixer FX in one of those 4 buttons, dont forget to edit both the MIXER_FXn and LED_MIXER_FXn keys in mapping
geposted Thu 22 Jul 21 @ 12:11 pm
Beyond the scope of a new user, but if on pc, virtualFX could make composite fx as a colorfx.
I don't use colorfx much, but noticing with your controller that's your only choice. It's got me thinking, there's one or two fx that be colorfx that aren't currently.
geposted Thu 22 Jul 21 @ 1:28 pm
