Q,
Is there an archive on vdj.com to select a previous build version say from vdj8-8.1 ?
I have a pro license from vdj7 and usually just install vdj7 and activate it then install the new version when the new version available popup appears,
Which is ok on my new laptop to jump to the latest version release but my old laptop will only run from vdj7 to around 8.1 without any issues but not good enough to run the latest version and don't want to stop using it just because of a version update.
Thanks
Thanks
geposted Tue 27 Jul 21 @ 1:31 pm
The newer versions should run better actually.
The only thing that takes more power is the stems separation. If your laptop is very old you can try to set the mathEngine option to disabled.
geposted Tue 27 Jul 21 @ 1:45 pm
Thankyou for the quick response i will give it a try :)
geposted Tue 27 Jul 21 @ 2:37 pm
If that does not work here is the link for previose builds https://virtualdj.com/download/build.html
geposted Tue 27 Jul 21 @ 8:28 pm
