Hey guys, I would like to put a a CD's worth of tracks into VDJ and have vdi auto crossfade all tracks and record the mix as one file but during the tracks playing I would like to add reverb and delay effects from a VST plugin anywhere in between the tunes, can VDJ do this please?
geposted Tue 27 Jul 21 @ 5:16 pm
Sure it can!
geposted Tue 27 Jul 21 @ 8:33 pm
I just need this for only 2 mixes, can this be done with the Home edition please?
geposted Tue 27 Jul 21 @ 9:10 pm
it can, home licence users can record & use vsts as freely pro users.
geposted Tue 27 Jul 21 @ 11:31 pm
Thanks guys, I am trying this all out now, only issue is the VST effects. Please see this screenshot here:
https://i.postimg.cc/VvgFJjfg/Screen-Shot-2021-07-28-at-9-50-47-AM.png
As you can see the youtube tutorial's layout is different from mine on the left and I do not have the "Effects" button to the left of the wheel as in the video. Can it be that I would indeed need to have the paid version to have this option for VST use please?
geposted Wed 28 Jul 21 @ 1:58 pm
choose a different skin layout.
geposted Wed 28 Jul 21 @ 2:22 pm
I am not seeing the exact layout as in that video, closest out of the 4 options is the Essentials layout:
https://i.postimg.cc/2S2bNwkj/Screen-Shot-2021-07-28-at-10-27-16-AM.png
It work with the Flanger drop down though!
geposted Wed 28 Jul 21 @ 2:29 pm
the video is 8.0 by the looks of it [5 - 6 years old]
read the bit on installing vsts
http://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/effects.html
bear in mind installing location is
VirtualDj\Plugins\SoundEffect
for 32 bit installs
VirtualDj\Plugins64\SoundEffect
for x64
for 32 bit installs
for x64
geposted Wed 28 Jul 21 @ 3:42 pm
Oh sorry I wasnt clear in my previous post. I have the VST working as it should and yes the YouTube videos showed the correct instructions. I want to try out the Autobeatmatching feature next.
I must say VDJ has come a long way since I had last used it years ago, I may end up using it instead of Serato.
geposted Wed 28 Jul 21 @ 4:48 pm
geposted Wed 28 Jul 21 @ 8:55 pm
Hey guys, only one issue I am noticing. Without any of VDJ's effects [backspin, delay e.t.c] activated, whenever I stop or pause the playing tunes, I am hearing an echo, I can hear it too when I hit Play, any ideas please?
geposted Fri 30 Jul 21 @ 12:51 pm
I'd guess your audio config is wrong, show us a picture.
geposted Fri 30 Jul 21 @ 1:29 pm
my mistake sorry, when I restarted vdi it works fine. Might have been some hiccup from trying all of the different effects, all his good, thanks!
Just one more question please, can I use another pane for Search results leaving the main browser as is please?
geposted Fri 30 Jul 21 @ 2:08 pm
could you explain why you want that, I know a few ways of doing things but none are an obvious answer to what you're asking.
geposted Fri 30 Jul 21 @ 2:35 pm
Sure. When I search for song it auto loads everything into the browser area removing the folder of tunes which was in there, would be easier if the playlist/browser area remains as is while I work on searching for whatever tunes in another pane/window, not a problem for me just checking in case it might be possible is all.
geposted Fri 30 Jul 21 @ 2:41 pm
Independent browsers is something asked many times
Currently only "goto_last_folder" can restore previous song list after a search
geposted Fri 30 Jul 21 @ 2:48 pm
@mikehende for your case just clear search
geposted Fri 30 Jul 21 @ 2:55 pm
Cool, no worries on an additional pane, thanks guys. I ran vdi on my DJ rig this morning at loud volume and everything works great including the VST effects, no complaints at all! Think I may need to upgrade my pc though as this old i5 12gb ram machine is a little slow, for my other applications too.
geposted Fri 30 Jul 21 @ 3:09 pm
little tip "i5" means very little as a technical descriptor, you can buy new i5's today. the number that follows is probably more important
i5 2XXX is more or less a museum piece [like 10 years old, 2nd generation]
i5 12XXX is a newer machine [12th generation]
geposted Fri 30 Jul 21 @ 3:21 pm
Great info which I will use when purchasing a newer unit, appreciate it.
geposted Fri 30 Jul 21 @ 3:43 pm
