Hi
I'm pretty new to the scripting in VDJ so this might be a stupid question but I searched on a lot of posts around here but didn't find a solution to my problem.
What I'm simply trying to do is activate the 'Filter LP' effect on a CUE point, and gently move the position of the slider on the effect from left to right in like 20 seconds (so it starts with 'Off' and at the end is should say "<20hz").
Effect at the beginning of the script:
Effect at the end of the script:
I hope somebody can help me out with this!
Thanks a lot!
Thanks a lot!
geposted Tue 03 Aug 21 @ 10:19 am
          something like that
    effect_active 'filter lp' on & effect_slider 'filter lp' 1 0 & repeat_start 'filtersweep' 50ms 400 & effect_slider 'filter lp' 1 +0.0025
geposted Tue 03 Aug 21 @ 11:33 am
locodog wrote :
something like that
Exactly what I was looking for! Thanks a lot man! Appreciated!
geposted Tue 03 Aug 21 @ 12:33 pm
          20 seconds is kind of arbitrary, there are ways to do beats [either beats progression or beat time] but that's slightly different.
    geposted Tue 03 Aug 21 @ 12:38 pm
Indeed, thanks for the info. One small question, what is the best way to reset the Filter LP after this script? Van I also add this to the script you already provided me?
Thanks again!
geposted Tue 03 Aug 21 @ 12:57 pm
          turn off?
or If say you were to also manually adjust the filter while this is in action it could be written
If/when you're looking for explanations to how that 'clockwork' actually works, this thread is probably the best place
http://www.virtualdj.com/forums/223743/General_Discussion/Script_School.html?page=1
    effect_active 'filter lp' on & effect_slider 'filter lp' 1 0 & repeat_start 'filtersweep' 50ms 400 & effect_slider 'filter lp' 1 +0.0025 & effect_slider 'filter lp' 1 1 ? effect_active 'filter lp' off & effect_slider 'filter lp' 1 0 & repeat_stop 'filtersweep' :
effect_active 'filter lp' on & effect_slider 'filter lp' 1 0 & repeat_start 'filtersweep' 50ms & effect_slider 'filter lp' 1 1 ? effect_active 'filter lp' off & effect_slider 'filter lp' 1 0 & repeat_stop 'filtersweep' : effect_slider 'filter lp' 1 +0.0025
geposted Tue 03 Aug 21 @ 2:17 pm
