Hello . I have the new MacBook Pro. 13in. Mi chip/ I installed virtual Dj / I have the VirtualDJ 2020 PRO Infinity License. / I use the pioneer SZ .
Went I connect to the pioneer, ot asks to download the drivers. Once the drivers had been downloaded, when I go to my Audio settings in the virtual Dj , the SZ does not show / pleas assist asap
geposted Sat 07 Aug 21 @ 5:22 pm
Check the security settings on the mac as it might be blocking something not sure how to do that as I run windows.
geposted Sat 07 Aug 21 @ 6:40 pm
Thank you for your response. I know you run windows but what my security settings should I be looking for?
geposted Sun 08 Aug 21 @ 7:24 am
Similar to this, but for your driver.
https://www.virtualdj.com/wiki/Settings-not-saving.html
geposted Sun 08 Aug 21 @ 7:28 am
locodog wrote :
thank you i will try this day.. fingers crossed!!
geposted Thu 12 Aug 21 @ 1:25 pm
driver should be under general.
geposted Thu 12 Aug 21 @ 2:25 pm
can you please explain "general"
geposted Thu 12 Aug 21 @ 6:41 pm
It's explained here in detail..
https://www.pioneerdj.com/en/support/software/archive/ddj-sz/#drivers
Note
If you still dont see the "Allow" button in General tab of Security & Privacy, you may need to enable System extensions
https://www.m3datarecovery.com/mac-bitlocker/enable-system-extension-m1-mac.html
Note
geposted Thu 12 Aug 21 @ 7:45 pm
