Updateed my software last night to latest version , i run a numark NVii on amacbook pro with big sur 11.5.1. Playing at gig and the right hand pads kept looking up having to press twive so had to use just play and cue, Also the mic input was not showing on software and wouldnt work. Tried re instalkling drivers today from your site still no joy can detect the mic input just one on macbook
geposted Sun 08 Aug 21 @ 8:35 am
Been a while since I looked at the NV, but I think the mic are hardware only, in other words not part of the USB audio interface, and hence not a computer accessible microphone.
It can only be controlled/user on the NV itself if so.
And if you want to record/broadcast with that mic, see here:
https://www.virtualdj.com/manuals/hardware/numark/nv/inputs.html
geposted Tue 10 Aug 21 @ 11:13 am
