Hi i recently experience a very bad rec quality.
All my settings are on hq , including wav rec. Doesnt change a thing.
The mic sounds nice, but the audio from the channels is super distorted as if gain is 300%. I lower and lower the gain level and it helps but of course i cant work with minimal gain on channels.
I use the ddjsx
And a standard sm 58 mic.
Help!!!
I use the ddjsx
Help!!!
geposted Mon 09 Aug 21 @ 8:43 am
Is it the same with recordBitDepth on 16-bit ?
What does your audio config look like?
geposted Mon 09 Aug 21 @ 8:49 am
Yes same with 16 bit
geposted Mon 09 Aug 21 @ 8:57 am
click the audio button on the left hand side of your pic on the options window and take a image of that :-)
not sure if your controller uses an external mixer. if it does not you should set auto gain to auto and zerodb to -3 and your recordings will probably be nice... also there may be some setting on your controler to adjust recording volume.
geposted Mon 09 Aug 21 @ 11:45 am
