Topic: Pioneer S11 Re-mapping Back buttons
I am trying to re-map the 2 back buttons on my S11 so that they toggle between 4 decks. i.e.
Left back button - Decks 1 & 3
Right back button - Deck 2 & 4
The issue I am having is that in the mapping setting both back buttons are seen as a single control point and so I can only configure Decks 1&3 or Deck2&4, but not both.
Is there a way to configure the back buttons so that they work independently to give the above control?
geposted Mon 09 Aug 21 @ 9:51 am
Thank you for your response and really useful document.
I did manage to find a work around with the following settings;
Back button - Invert deck switches to decks 3&4 on assigned left/right channels.
Double tap back button - Deck 1
Shift back button - Deck 2
Regarding the Invert deck command, is there something which can be added the the script to return the channels back to decks 1&2
deck left invert_deck & deck left select
deck right invert_deck & deck right select
I have something like this.
Please some one can help me with GATECUE and TRANSPORT don't work on my DJM-S11 but on DJM-S7 works perfectly ..
Thanks your help
