Topic: vdjedit files & playlists
DJMBR01PRO InfinityMember since 2015
Is it not possible to add an edited file to a playlist?
I used the track editor and cannot add the edited version to a playlist.
P.S. I am using the most current "Summer" version of VDJ.
geposted Mon 09 Aug 21 @ 2:03 pm
Seems to work here, I just dragged an edit into a playlist. How are you trying?
geposted Mon 09 Aug 21 @ 2:17 pm
Thanks for the reply loco but I'm using the same method you describe.
Edit file.
Find file in inventory.
Drag over to playlist (not autoplaylist).
No luck.
geposted Mon 09 Aug 21 @ 6:57 pm
NicotuxHome userMember since 2014
tested different edit types and initial filetypes with sidelist, playlist and karaoke
everything works ok here
maybe your sidelist have write permission issues ?
geposted Mon 09 Aug 21 @ 7:11 pm
I'll have to dig into that.
geposted Mon 09 Aug 21 @ 7:15 pm
Where/What setting deals with playlist permissions?
geposted Tue 10 Aug 21 @ 2:52 am
there is settings -> browser -> readOnly
and of course OS folders permissions
but note there is a possibility VDJ crashed and crashguard restarted VDJ in readonly mode (before database was released by previous instance)
geposted Tue 10 Aug 21 @ 3:39 am
freppaPRO InfinityMember since 2002
Had to try this.
Works for me too on both 32/64 bit versions with drag on sidelist and automix list.
geposted Tue 10 Aug 21 @ 4:49 am
After 2 reboots, a recurse and a routine bulk analyze, the problem has resolved itself.
geposted Mon 16 Aug 21 @ 3:14 pm
P.S. ...friggin Windows.
geposted Tue 17 Aug 21 @ 1:00 pm
