When in using DVS , if I adjust one song's tempo on say, deck A, to be a non-zero percentage, then I load a new song into that deck, it seems like the relative zero position changes. The BPM is some combination of the previous percentage setting plus more - when i reset the turntable pitch slider to zero, the software BPM is not zero.
What settings do I need to enable/disable to resolve this behavior?
geposted Tue 10 Aug 21 @ 12:42 am
try the
resetPitch
pitch option to off
also check the
autoBPM
option
resetPitch
pitch option to off
also check the
autoBPM
option
geposted Wed 11 Aug 21 @ 12:03 am
Sorry, I realize I missed an important piece of info in the original problem description.
I did originally have the following off (no):
- resetPitchOnLoad
- autoBPMMatch
But the problem happens when I instant double a track to the other deck (using my DJM S9). It seems that the new deck matches the BPM of the original deck, regardless of the turntable pitch setting, which was unexpected for me.
- resetPitchOnLoad
- autoBPMMatch
geposted Wed 11 Aug 21 @ 12:13 pm
It seems that what I want is the instant double to clone the deck without the pitch. It seems like there used to be a verb to do this in earlier versions of VirtualDJ (clone_deck_nopitch), but I do not see that verb now.
Is there any way to get that functionality back?
geposted Sat 21 Aug 21 @ 2:38 pm
