I recently upgraded my laptop. Now when I connect my controller, the music pauses for a few seconds randomly then starts again. I seem to remember seeing or hearing such issues may be incompatibility between the USB 2 or the controller and USB 3 of the laptop (despite it supposedly being backwards compatible).
Can anyone recommend a convertor to fix this issue?
geposted Mon 16 Aug 21 @ 4:12 pm
This is totally normal, USB 3.x are not fully USB 1.x or 2.x backwards compatible
the data flow can be interrupted with 3.x when it is permanent with previous versions
the solution being to use a USB 2.x hub
geposted Mon 16 Aug 21 @ 5:24 pm
Not 'normal' at all, and only an issue with usb controllers in the first few years after USB 3 was available afaik.
geposted Mon 16 Aug 21 @ 5:26 pm
yes that's right but a lot of "old" devices have this issue, not "normal" but common ;)
geposted Mon 16 Aug 21 @ 5:35 pm
Thanks everyone - on further investigation, the issue is the ASIO driver for the controller - Behringer only provide an 8.1 driver and so Windows 10 doesn't see to work. Might be time for a new controller :(
geposted Sat 21 Aug 21 @ 5:22 pm
I'm having the same problem with the skipping. I just started using a new mixer pioneer DDJ-400.
geposted Mon 20 Sep 21 @ 2:28 am
