Still only see "length" as a parameter setting for either the backspin effect or the backspin FX pad mode. Where am I missing the number of beats parameter settings?
geposted Wed 18 Aug 21 @ 5:14 pm
You can use it in combination with the backspin action on a button for example
'backspin 1bt'
'backspin 1bt'
geposted Wed 18 Aug 21 @ 5:30 pm
Thank you for the quick response. The following (effect_active 'backspin 1bt') doesn't do anything. Am I writing the script wrong?
geposted Wed 18 Aug 21 @ 5:51 pm
just this
backspin 1bt
backspin is an action separate to the fx
backspin 1bt
geposted Wed 18 Aug 21 @ 5:54 pm
For the effects, you can use effect_beats
'effect_beats backspin 1.0'
geposted Wed 18 Aug 21 @ 6:15 pm
That works! Thank you so much!
geposted Wed 18 Aug 21 @ 6:26 pm
