Topic: Low FPS while in fullscreen
After the most recent update to virtual dj, I noticed the whole software started lagging at an unbearable frame rate, like 10 or so FPS. Typing into the search is extremely delayed, scrolling is very choppy, the waveform chugs along, and loading songs takes longer than usual. The issue is only present when the application is in full screen. It runs perfectly smooth at 60fps when windowed… anyone have any solutions?
geposted Mon 23 Aug 21 @ 4:06 am
NicotuxHome userMember since 2014
Depending on builds down to 5FPS or more 75FPS using same system
but 75 FPS down to 5 FPS with other system using same build ^^
Most of the time (not always) using experimentalSkinEngine increase FPS but give many issues
This is not only fullscreen but fullscreen increases the visibility of the issue
windowed mode can decrease down to 23FP with some systems
As system usage is very low, this seems to be engine optimization difficulty
(i.e. core 2 duo in CPU mode does 50FPS using 95% CPU far better i5 gen 4 with nVidia quatro 5FPS using 20% CPU ^^)
geposted Mon 23 Aug 21 @ 4:14 pm
