Topic: Downgrade to an early build on Mac
I have 8.5b 6613 and my beatsource link is giving me an error 77 message. I would like to downgrade to an early build. Do i have to uninstall the ver i have or can it write over it and what is the easiest way to do this? Thank you
geposted Fri 27 Aug 21 @ 2:40 am
geposted Fri 27 Aug 21 @ 2:54 am
Try that did not work. It is at the latest build. I cant see to get Beatsourse to work. After it says log in successful i got back to VDJ and it says log in fail 77 i did not have this issue on an earlier build.
geposted Fri 27 Aug 21 @ 3:01 am
The error probably comes from beatsource directly.
You can try to remove the Documents/VirtualDJ/cache/beatsource folder and then try to log in again
geposted Fri 27 Aug 21 @ 3:48 am
Is there an easy way to find this folder on mac? I do not see it under applications.
geposted Fri 27 Aug 21 @ 6:16 pm
Documents should be under your user name in finder
geposted Fri 27 Aug 21 @ 6:24 pm
Thank you. found it. i deleted the best source folder cache folder and re started VDJ and same error message Login failed 77
geposted Fri 27 Aug 21 @ 7:32 pm
build 6613 still beatsourse not working :(
geposted Mon 30 Aug 21 @ 3:58 pm
Did you contact beatsource support?
geposted Mon 30 Aug 21 @ 3:59 pm
Yes, they said it is a VDJ issue within the software.
geposted Mon 30 Aug 21 @ 4:34 pm
Could you take a screenshot of the error message?
Will see if I can get more information from the beatsource developers about this error message, since it is not coming from VirtualDJ
geposted Mon 30 Aug 21 @ 5:30 pm
