Topic: Delete the song from the deck
I can delete a song from the deck by mapping a key with "unload". In Automix-mode, however, the song can not be deletet with "unload". What do I have to do to delete the song anyway ?
geposted Fri 27 Aug 21 @ 12:23 pm
Select the Track you want to remove, then press DELETE on your keyboard.
geposted Fri 27 Aug 21 @ 12:28 pm
browser_remove can be used to delete the selected track from the selected list
geposted Fri 27 Aug 21 @ 1:40 pm
It's not about deleting a song from a list. Rather, the aim is to remove a song that is already in the deck. So the song should be removed from the deck. This is basically possible with the mapping command "unload".
But it is not possible in Automix mode.
I haven't found a solution here yet.
geposted Sat 28 Aug 21 @ 12:19 pm
Since it sounds like you don't want to disable automix, automix_skip then, which will load the next song.
geposted Sat 28 Aug 21 @ 12:50 pm
tommo1PRO InfinityMember since 2010
Right click on the stop button on the deck you want to unload should do the trick
geposted Sat 28 Aug 21 @ 4:56 pm
Many thanks for the tips. Will try everything
geposted Mon 30 Aug 21 @ 10:42 am
