Hi
When I used virtual dj, I had a problem! When I wanted to transfer a file from the USB stick to the desktop, virtual dj freeze for a few seconds. Same if I put files in the Recycle Bin?
MacBook Pro and last version on virtual dj
Thank you
Thank you
geposted Sun 29 Aug 21 @ 9:14 pm
sounds like your hard drives are going to sleep
check your power settings for them
geposted Sun 29 Aug 21 @ 10:12 pm
But with the last version i never had this problem !
Where a can Check this?
geposted Sun 29 Aug 21 @ 10:18 pm
geposted Mon 30 Aug 21 @ 1:54 am
