Trying to setup a filter for compabilty songs only for one drive.
Seems is just work for folders not a drive.
So what is the correct string?
Question 2:
By slipping with my mouse I accendently deleted the Duplicate filter when moving.
Searched all internet but the default string (command line) is not present or I don't know how and where to find it.
Bpm Difference <= 2 and Key Difference = 0 and Drive is G:\
Question 2:
geposted Tue 31 Aug 21 @ 9:58 am
1.
2. If you cant find that Filter Folder , simply create one with criteria ...
Bpm Difference <= 2 and Key Difference = 0 and Drive is Gworks here
duplicates
geposted Tue 31 Aug 21 @ 11:04 am
djdad wrote :
1.
Just a simple G without :\ did the trick Thank you!
duplicates
Image didn't help me much. Click advanced and you got the string that I'm after
Thanx
geposted Tue 31 Aug 21 @ 2:01 pm
geposted Tue 31 Aug 21 @ 2:08 pm
Thx, That was easier than I thougt =o)
geposted Sun 05 Sep 21 @ 10:15 pm
