Hello all,
I probably have a small issue with mapping a short-cut on the keyboard.
I want to load a song that is highlighted in the browder to the active deck or say deck 1, 2 etc... The problem is that the function only works once and then not anymore.
I use the function "load"
Does some have a solution?
geposted Wed 01 Sep 21 @ 8:45 pm
One correction about my previous post.
I not can use the shortcut once, but everytime i have used it i must touch the jogwheel to use it again.
After touching the jogwheel (with mouse) the shortcut works again.
I can`t find anything in the mapping that is strange (it is the default keyboard mapping that i am using).
Anyone?
Anyone?
geposted Thu 02 Sep 21 @ 7:27 am
