Topic: CAN'T OPEN
VIRTUAL DJ EXE ENTRY POINT NOT FOUND
geposted Thu 02 Sep 21 @ 4:17 pm
Are you using Windows 10?
If not you should upgrade, or use the 32-bit version of VirtualDJ
geposted Thu 02 Sep 21 @ 4:24 pm
paxwebbPRO InfinityMember since 2009
What version do I need to roll back to in order to run on Windows 8.1? Where can I find this download?
geposted Thu 02 Sep 21 @ 4:58 pm
If you download from that machine it will detect it's 32 bit and install the correct version.
geposted Thu 02 Sep 21 @ 5:01 pm
I use 64 bit VDJ and I did download from inside the app, but now I can't open VDJ. FYI, previous versions of VDJ run fine on Windows 8.1. I just need to know the last, stable build that I can run, and I won't update in the future. I found the download page, but need the correct build to select before downloading:
https://www.virtualdj.com/download/build.html
geposted Thu 02 Sep 21 @ 5:09 pm
6541 is the last 64-bit version that might run on windows 8
geposted Thu 02 Sep 21 @ 5:15 pm
Confirmed. Build 6541 works great on Windows 8.1. Thanks for the quick replies!
geposted Thu 02 Sep 21 @ 5:31 pm
