When I try to export files or browse folders VDJ does not see my phone as a drive. When I open the drive in Windows explorer and try to drag the file to a deck it will not load. VLC is able to play the file directly from the phone.
It apears that it is because it shows up as a media device and does not get a drive letter. I am not having any luck trying to get it a drive letter.
geposted Sat 04 Sep 21 @ 5:24 pm
Depends on phone and Android version
Most of the time 4 modes exist : Charge and MTP and PTP and USB network sharing
USB MSC, or UMS can exist too and is the simplest but obsoleted
In a way to get the phone mapped to a letter using windows UMS or MTP must be selected
WARNING: Some phone need the phone to be open for this to work
https://www.dummies.com/consumer-electronics/smartphones/droid/how-to-configure-your-androids-usb-connection/
https://www.howtogeek.com/192732/android-usb-connections-explained-mtp-ptp-and-usb-mass-storage/
as usual correct device driver have to be installed (should be automatic though)
geposted Sat 04 Sep 21 @ 10:38 pm
I'll check if we can support media devices in virtualdj as well.
geposted Sun 05 Sep 21 @ 4:29 am
That would be great, thank you!
Thank you Nicolux, I've explored this briefly. Hopefully Adion can come up with a solution so I don't have to try and get each computer I use to work.
geposted Mon 06 Sep 21 @ 4:53 pm
