Hi guys..something thats been bugging me..whenever I open Virtual dj 2021 it goes back to Hot cues normal tho i need the Hot cues 16 pluin instead..ikn vdj 2020 and prior the plugins i chose last stays in as the chosden on the pads..anyway of keeping there?..
geposted Mon 06 Sep 21 @ 4:12 am
sounds like you need to sort your controller pad slots.
geposted Mon 06 Sep 21 @ 4:14 am
you mean from that dropdown menu /matrix section,next to the pads Loco?...duh...not messed with that yet..
geposted Mon 06 Sep 21 @ 7:04 am
You can enable sixteenPadsMode in options
geposted Mon 06 Sep 21 @ 7:16 am
Thanks guys.. will check that out.
geposted Mon 06 Sep 21 @ 6:20 pm
