Topic: Changed cue points outside of Virtual DJ
doug9474ControlleristMember since 2019
Because MixedInKey added a lot of useless cue points to most of my files, I removed cue points outside of Virtual DJ. However, when I load a file in Virtual DJ, the cue points are still there. Is there some cache somewhere outside of the mp3 file that I need to remove cue points from before they go away in Virtual DJ?
geposted Sat 11 Sep 21 @ 7:01 pm
turn off the setting that loads cues from the Tag
geposted Sat 11 Sep 21 @ 8:23 pm
NicotuxHome userMember since 2014
... or maybe the opposite, because database have cues that were removed from file with third party software
getCuesFromTags to on
setTagsAuto may be set to no
geposted Sat 11 Sep 21 @ 8:33 pm
Before I saw the replies, I ended up using the vim text editor to remove the matching lines with the cue points from the database.xml file.
geposted Sat 18 Sep 21 @ 7:11 pm
