I'm not sure if anyone at Atomix noticed my recent post here:
https://www.virtualdj.com/forums/243062/VirtualDJ_Technical_Support/Adjusting_loop_in_out_points_on_DDJ-RZ.html
I found that the DDJ-RZ mapping that VDJ saved after I made modifications to the default, had several things missing from it, which I had to add back in manually.
Can somebody please check to make sure this doesn't happen? Thanks.
geposted Sun 12 Sep 21 @ 2:18 pm
Is anyone looking into this?
geposted Tue 14 Sep 21 @ 4:31 pm
I just replied on your original topic. No need to keep two topics running for the same issue.
If you have more questions use the other one and I'll follow back! :)
geposted Tue 14 Sep 21 @ 5:25 pm
