Topic: Gemini G4 Driver Issues, which to use?
I have a Gemini G4 controller and I'm using the following outputs; booth, headphones, and a line input for a mic. When starting Virtual DJ Pro and in the audio set up, I have both a Gemini G4 (ASIO) and Gemini G4 (WASPI) drivers. No matter which one I pick, booth works fine, and headphones work here and there, but the pre-fade on the controller doesn't work...I get the full audio through the headphones, no pre-fade. Depending on switching drivers options around, at times I'm hearing cuing on Deck 2 through my booth speakers.....any ideas what I'm doing wrong. I don't have anything going through master output since I'm running the entire op through usb.
geposted Sun 12 Sep 21 @ 7:55 pm
Think it's fixed.
Got it figured out.
