Topic: F-key for Samples
magn8PRO InfinityMember since 2009
Since the last update, my samples won't starting by using the F-keys. On both systems. Any idea?
geposted Sun 12 Sep 21 @ 8:48 pm
NicotuxHome userMember since 2014
yes,
in current ea keyboard mapping change and testing mapping engine is highly broken
you can select "factory default (legacy)" as a keyboard mapping in settings
but new maping engine may gives some side effects anyway
best way reverse to stable release
geposted Sun 12 Sep 21 @ 9:24 pm
