Using this code but it not changing the folder path with pressing actual pad. What have I missed?
Takes to long time to change it manual. Menu, cogwheel, press folder change, menu, scroll from top to bottom, choose folder.
deck master get_effect_string 'slideshow' 1 'D:\Virtual DJ Slideshow Video\Coaster'
geposted Tue 14 Sep 21 @ 10:57 am
remove "get_"
geposted Tue 14 Sep 21 @ 11:02 am
I'm a fool... =o)
Of course it works if you enable the deck master..
It is the video source I want to use. what is the parameter
video_source effect_string 'slideshow' 1 'D:\Virtual DJ Slideshow Video\Shuffle dance'
geposted Tue 14 Sep 21 @ 12:28 pm
effect_string 'audioonlyvisualisation' 1 "FILEPATH"
geposted Tue 14 Sep 21 @ 12:45 pm
Big thank you Locodog!
geposted Tue 14 Sep 21 @ 12:58 pm
