I have been doing a lot of database clean up along with tag fixing and file renaming. All this work is being done inside VDJ. I was recursing some folders and came across this. I recursed the entire database inside the my library folder and every song came up 4 times and I can't figure out why?
_LI.jpg)
All help is appreciated
Joe
_LI.jpg)
Joe
geposted Tue 14 Sep 21 @ 3:44 pm
It seems you recursed a virtual folder with several virtual folder and filter folder subfolders it seems. If more than one of these contain the same song then it will appear multiple times
geposted Tue 14 Sep 21 @ 3:56 pm
Nothing to worry about. just use "All Files" filter one bellow.
geposted Tue 14 Sep 21 @ 3:57 pm
Thanks Guys I got it now
geposted Tue 14 Sep 21 @ 4:04 pm
