my faders suddenly changed. fader 1 on my numark nvii controller doesn't show fader 1 in vdj but shows that fader 3 is engaged on screen. i've reset the controller to factory default but the issue continues . could someone lend a little assistance ? thank you
    geposted Thu 16 Sep 21 @ 10:44 pm
          controllers/mapping window, check the choices for the deck order with the dropdown titled "deck"
    geposted Thu 16 Sep 21 @ 10:56 pm
          I would suggest not to change the Deck assignment from MAPPING.
Most of the 4ch controllers (incl NVII) support the Mixer Order. So if the skin you use supports this, the faders on the skin should follow what you have on your controller.
https://www.virtualdj.com/manuals/virtualdj/interface/mixer/audio.html#4deck Nr.13
So, what skin are you using (if not the 4 Decks Pro Default) ?
geposted Fri 17 Sep 21 @ 1:44 pm
