Good Evening,
I have two simple questions:
1. If want to export all of my settings from one pc to another, where would I find the complete set? It has been a while since I set up a new pc and have forgotten.
2. I have DDJ-1000 controller and also have a Hercules Starlight Controller. I really appreciate the quantize function and actual button on the DDJ but the Starlight is a simple little portable that has no such thing. Is it possible to create a virtual button within VirtualDJ to turn on and off quantize.
Thanks in advance to this very helpful group!
geposted Fri 17 Sep 21 @ 6:08 am
C:\Users\user\Documents\VirtualDJzsettings.xml
or something like that
quantize_setcue
quantize_loop
quantize_all
these above are available scripts and of course there's still the settings scripts too
settings quantizeLoop
quantize_setcue
quantize_loop
quantize_all
geposted Fri 17 Sep 21 @ 6:17 am
Hi LocoDog!!! Sorry for having such poor forum manners. Thank you for your help and recommendations months ago. I have been swamped at work and have not been on the forum since traveling back in September. Your tips are immensely helpful as there is so much in VDJ and sometimes remembering it all is a challenge.
Many Thanks!!!
Many Thanks!!!
geposted Wed 16 Feb 22 @ 3:24 am
PS: The "Quantize" button on DDJ-1000 uses "quantize_all" as an action.
Therefore that's the one you'll want to copy since you are allready acustomed with how it works
geposted Thu 17 Feb 22 @ 11:19 am
