Edited...
geposted Fri 17 Sep 21 @ 7:06 pm
deck 2 repeat_start 'rsiFadeD' 120ms -1 & level 0 ? repeat_stop 'rsiFadeD' & unload & volume 100% : level -0.04
to delay action for 4 secs
repeat_start 'waittime' 4000ms 1 & action
geposted Fri 17 Sep 21 @ 7:27 pm
Thank you! That worked great! One more thing I'd like to test, if it's possible in the same command... how would I get it to, say, perform another action after 1500ms of the first action, without delaying or affecting the ones waiting until the end? So say I wanted to start deck 1 after 1500ms (which is part way through the time it takes to do the rsiFadeD), is it possible to do that in the same command?
geposted Fri 17 Sep 21 @ 7:43 pm
A couple of ways, rsi's calling rsi's can be problematic but as a "wait" it's not so bad
repeat_start 'waittime' 4000ms 1 & action & repeat_start 'waitMOREtime' 15000ms 1 & action
geposted Fri 17 Sep 21 @ 7:48 pm
directly in one script I do not think so
some workaround using external script may depend on the location of the script
custom button, pad, map, or multibutton nothing is working the same
