i want to re-download the echo out effect. after the recent update i don't have it anymore. why did it get kicked out?? i looked for it in the effects download and didnt see it.
geposted Sat 18 Sep 21 @ 3:35 pm
You are not the only one I lost that ages ago windows 10 numark mixtrack pro 2
geposted Sat 18 Sep 21 @ 3:47 pm
It's a native effect, I can't remember if you need to "install" it but it's there on the extensions page
geposted Sat 18 Sep 21 @ 3:55 pm
The echo effect is the one that is built in and when it is selected the pad lights up as normal and then nothing happens and when ajusting with the controller knob still nothing until turning it fully to the right the audio is muted.
geposted Sat 18 Sep 21 @ 5:05 pm
Up date BFX- Echo works thanks
geposted Sat 18 Sep 21 @ 5:09 pm
"Echo Out" is also a native fx, I use it regularly as a sampler when loop drumming.
geposted Sat 18 Sep 21 @ 5:18 pm
As Locodog as mentioned ... Echo Out is a native FX , that is installed from the Extensions Tab.
And I find they all work perfectly.
(See screen shot, of where to find them to install)
geposted Sat 18 Sep 21 @ 7:39 pm
I went through all the effects. I never saw a extentions tab
geposted Sun 19 Sep 21 @ 7:22 pm
It was added as of BUILD 6067 (2020-08-16)
geposted Sun 19 Sep 21 @ 7:49 pm
The old echo out on VDJ 7 is not compatible with VDJ 8. I have been using the Loop Out effect. I just tweaked the setting to my liking.
geposted Tue 28 Sep 21 @ 2:28 am
