i upload a song and it takes almost 15sec to upload to be able to play what do i do to make it upload right away
geposted Sat 18 Sep 21 @ 9:10 pm
If you have the stems enabled change it to precompute only
geposted Sat 18 Sep 21 @ 11:09 pm
it still does it
geposted Sun 19 Sep 21 @ 12:34 am
If you want the waveform (for stems) to draw quickly when you load tracks to the decks, then you need a computer with a dedicated GPU above a certain spec.
See here https://www.virtualdj.com/wiki/Minimum%20system%20requirements.html
geposted Sun 19 Sep 21 @ 8:39 am
my computer does have all of that
geposted Wed 22 Sep 21 @ 2:03 pm
