Is it possible to have more than 4 custom buttons per deck? I want to add two more for loading and saving deck sets. Or can it be mapped to a keyboard shortcut?
    geposted Thu 23 Sep 21 @ 9:37 pm
          number of custom buttons depends on skin
and everything can be mapped to keyboard key
see settings -> mapping and select keyboard as controller
geposted Thu 23 Sep 21 @ 9:44 pm
          Gotcha! Let me try that…….
    geposted Thu 23 Sep 21 @ 11:16 pm
          That worked! Thanks bro!
    geposted Fri 24 Sep 21 @ 1:01 am
          New question……I have custom buttons in one skin……if I change skins  in order to have more custom buttons, will the custom buttons follow or will I have to set them up again?
    geposted Fri 24 Sep 21 @ 1:05 am
          custom buttons are saved in config
their definition does not depends on skin
what is dependent is their number and which button are shown
as well same custom button can show as a simple push button or as a slider depending on skin
geposted Fri 24 Sep 21 @ 2:14 am
