To find out what drive letter the files showing that are no longer connected is, right click on a file then click on File Infos
If it is say E: you want to delete
Type E: in the search bar, click on the top file of the list you need to remove, then hold down Shift, Ctrl and End, then right click on the list of files and choose remove from DB
geposted Sat 25 Sep 21 @ 3:33 pm
Don't forget to select "filepath" in search options
(drive is no more selectable)
you can create a filter folder too
Name : "Missing by drive"
filter : "Exists = 0 group by Drive"
it helps with drive = (none) which are online missing files or search
it looks like "remove missing files from database" does not affect not connected devices
geposted Sat 25 Sep 21 @ 3:59 pm
