I pulled out the old Quneo just to have a change of pace controller. Has anyone on the forum mapped the quneo to be able to use stems? The default VDJ mapping does not allow for the use of stems. Thanks in advance for your assistance. I know that the brilliant people in the forum can help.
geposted Sat 25 Sep 21 @ 11:07 pm
well the mapping is 8 years old. but remapping is simple
check the description for the action
stem
stem
geposted Sun 26 Sep 21 @ 12:10 am
@locodog I called myself trying that, but for some reason it is not working for me.
geposted Sun 26 Sep 21 @ 12:45 am
for some reason I can't see the mapping in the mapping editor. [despite installing]
can you give examples of what you tried.
Key: your key, Action: action you tried adding
geposted Sun 26 Sep 21 @ 12:53 am
@locodog
it appears under the denomination "KeithMcMillen QuNeo"
need the device to be configured with specific config downloadable from "source" icon
it is buggy because of
- "set" bug
- testing against uninitialized variable behavior changed
- "set" bug
geposted Sun 26 Sep 21 @ 1:27 am
ONINIT : set "$fx" 1 & set "$cue" 1 & set "$play" 1 & var "$bigshift" 0 & var "$shift" 0 & set "$filterL" 1 & set "$filterR" 1
now writes
set "$fx" 1 & set "$cue" 1 & set "$play" 1 & set "$bigshift" 0 & set "$shift" 0 & set "$filterL" 1 & set "$filterR" 1
maybe enough, as long as QuNeo Editor can import the VirtualDJ Preset "VirtualDJ.quneopreset" to the QuNeo
(Can't test as I do not have this controller)
now writes
geposted Sun 26 Sep 21 @ 1:48 am
