Topic: Factory Default Skin
I have Virtual DJ Pro - I fooled around with skins and I cannot seem locate the factory default skin I had before I changed it. Can you tell me how to get that back? I am not new but it has been a while.
Thanks
geposted Sun 26 Sep 21 @ 2:17 pm
Just reinstall VDJ over the current installation.
Thanks, I did reset it to default like you stated above but that is still not the skin I had before I fooled around with it. I am ok with re-loading the software but I don't see where I can do that on the licensing page. Like I did not see that option.
maybe you were on "Old"
I tried them all, even went to other skins online that I can download and did not find default. :(
If you go to documents > virtual dj > skins > then remove the skin that you have changed to from the skin folder & start virtual dj it should revert back to the software default skin
